Cześć,
Mam problem z kartą sieciową Intel AX210 nie wykrywa mi na laptopie Dell 7480. Posiadam system Manjaro 21.1.6
Po instalacji system nie wykrywa tej karty. Karta LTE i ethernet działa bez problemu.
[damian-latitude7480 damian]# lshw -short | grep network
/0/100/1c.2/0 network Wi-Fi 6 AX210/AX211/AX411 160MHz
/0/100/1f.6 enp0s31f6 network Ethernet Connection (4) I219-LM
/2 wwp0s20f0u2i12 network Ethernet interface
H/W path Device Class Description
system Latitude 7480 (07A0)
/0 bus Motherboard
/0/0 memory 64KiB BIOS
/0/45 memory 16GiB System Memory
/0/45/0 memory 8GiB SODIMM DDR4 Synchronous Unbuffered (Unregistered) 2133 MHz (0,5 ns)
/0/45/1 memory 8GiB SODIMM DDR4 Synchronous Unbuffered (Unregistered) 2133 MHz (0,5 ns)
/0/49 memory 128KiB L1 cache
/0/4a memory 512KiB L2 cache
/0/4b memory 3MiB L3 cache
/0/4c processor Intel(R) Core(TM) i5-7300U CPU @ 2.60GHz
/0/100 bridge Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers
/0/100/2 display HD Graphics 620
/0/100/4 generic Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem
/0/100/14 bus Sunrise Point-LP USB 3.0 xHCI Controller
/0/100/14/0 usb1 bus xHCI Host Controller
/0/100/14/0/1 input 2.4G Mouse
/0/100/14/0/2 input YubiKey OTP+FIDO+CCID
/0/100/14/0/5 multimedia Integrated Webcam_HD
/0/100/14/0/7 communication Bluetooth wireless interface
/0/100/14/0/8 input Touchscreen
/0/100/14/0/a generic 5880
/0/100/14/1 usb2 bus xHCI Host Controller
/0/100/14/1/2 communication DW5811e Snapdragon
/0/100/14.2 generic Sunrise Point-LP Thermal subsystem
/0/100/15 generic Sunrise Point-LP Serial IO I2C Controller #0
/0/100/15.1 generic Sunrise Point-LP Serial IO I2C Controller #1
/0/100/15.2 generic Sunrise Point-LP Serial IO I2C Controller #2
/0/100/16 communication Sunrise Point-LP CSME HECI #1
/0/100/16.3 communication Sunrise Point-LP Active Management Technology - SOL
/0/100/17 scsi2 storage Sunrise Point-LP SATA Controller [AHCI mode]
/0/100/17/0.0.0 /dev/sda disk 512GB Micron 1100 SATA
/0/100/17/0.0.0/1 /dev/sda1 volume 99MiB Windows FAT volume
/0/100/17/0.0.0/2 /dev/sda2 volume 15MiB reserved partition
/0/100/17/0.0.0/3 /dev/sda3 volume 114GiB Windows NTFS volume
/0/100/17/0.0.0/4 /dev/sda4 volume 507MiB Windows NTFS volume
/0/100/17/0.0.0/5 /dev/sda5 volume 20GiB EXT4 volume
/0/100/17/0.0.0/6 /dev/sda6 volume 20GiB EXT4 volume
/0/100/17/0.0.0/7 /dev/sda7 volume 6999MiB Linux swap volume
/0/100/17/0.0.0/8 /dev/sda8 volume 312GiB Windows NTFS volume
/0/100/17/0.0.0/9 /dev/sda9 volume 628MiB Windows FAT volume
/0/100/1c bridge Sunrise Point-LP PCI Express Root Port #1
/0/100/1c/0 mmc0 bus RTS525A PCI Express Card Reader
/0/100/1c.2 bridge Sunrise Point-LP PCI Express Root Port #3
/0/100/1f bridge Sunrise Point LPC Controller/eSPI Controller
/0/100/1f.2 memory Memory controller
/0/100/1f.3 multimedia Sunrise Point-LP HD Audio
/0/100/1f.4 bus Sunrise Point-LP SMBus
/0/1 system Motherboard registers
/0/2 system AT Real-Time Clock
/0/3 generic PnP device INT3f0d
/0/4 input IBM Enhanced keyboard controller (101/2-key)
/0/5 system Motherboard registers
/0/6 system Motherboard registers
/0/7 system Motherboard registers
/0/8 system Motherboard registers
/1 power DELL 2X39G
Powiem szczerze, że mam małą wiedzę dlatego proszę o pomoc i z gó©y dziękuję.
