Witam jestem po aktualizacji/restarcie/przeinstalowaniu Steam-a i dalej nic
steam
10s
steam.sh[6125]: Running Steam on manjarolinux 23.0.0 64-bit
steam.sh[6125]: STEAM_RUNTIME is enabled automatically
setup.sh[6199]: Steam runtime environment up-to-date!
steam.sh[6125]: Steam client’s requirements are satisfied
[2023-08-05 15:50:31] Startup - updater built Jul 28 2023 18:44:09
[2023-08-05 15:50:31] Startup - Steam Client launched with: ‘/home/fisqs/.local/share/Steam/ubuntu12_32/steam’
08/05 15:50:31 Init: Installing breakpad exception handler for appid(steam)/version(1690583737)/tid(6266)
Looks like steam didn’t shutdown cleanly, scheduling immediate update check
[2023-08-05 15:50:31] Loading cached metrics from disk (/home/fisqs/.local/share/Steam/package/steam_client_metrics.bin)
[2023-08-05 15:50:31] Using the following download hosts for Public, Realm steamglobal
[2023-08-05 15:50:31] 1. https://client-update.akamai.steamstatic.com, /, Realm ‘steamglobal’, weight was 1000, source = ‘update_hosts_cached.vdf’
[2023-08-05 15:50:31] 2. https://cdn.cloudflare.steamstatic.com, /client/, Realm ‘steamglobal’, weight was 1, source = ‘update_hosts_cached.vdf’
[2023-08-05 15:50:31] 3. https://cdn.steamstatic.com, /client/, Realm ‘steamglobal’, weight was 1, source = ‘baked in’
[2023-08-05 15:50:31] Checking for update on startup
[2023-08-05 15:50:31] Wyszukiwanie dostępnych aktualizacji…
[2023-08-05 15:50:31] Downloading manifest: https://client-update.akamai.steamstatic.com/steam_client_ubuntu12
[2023-08-05 15:50:31] Manifest download: send request
[2023-08-05 15:50:31] Manifest download: waiting for download to finish
[2023-08-05 15:50:32] Manifest download: finished
[2023-08-05 15:50:32] Download skipped: /steam_client_ubuntu12 version 1690583737, installed version 1690583737, existing pending version 0
[2023-08-05 15:50:32] Nothing to do
[2023-08-05 15:50:32] Weryfikowanie instalacji…
[2023-08-05 15:50:32] Performing checksum verification of executable files
[2023-08-05 15:50:32] Verification complete
XRRGetOutputInfo Workaround: initialized with override: 0 real: 0xe8b15db0
XRRGetCrtcInfo Workaround: initialized with override: 0 real: 0xe8b14500
GetWin32Stats: display was not open yet, good
steamwebhelper.sh[6294]: Runtime for steamwebhelper: defaulting to /home/fisqs/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
steamwebhelper.sh[6294]: glibc >= 2.34, partially disabling sandbox until CEF supports clone3()
CAppInfoCacheReadFromDiskThread took 180 milliseconds to initialize
Assertion ‘device’ failed at src/libsystemd/sd-device/device-private.c:103, function device_get_tags_generation(). Aborting.
crash_20230805155035_26.dmp[6449]: Uploading dump (out-of-process)
/tmp/dumps/crash_20230805155035_26.dmp
crash_20230805155035_26.dmp[6449]: Finished uploading minidump (out-of-process): success = yes
crash_20230805155035_26.dmp[6449]: response: CrashID=bp-3e28991f-2355-476d-987e-2156e2230805
crash_20230805155035_26.dmp[6449]: file ‘’/tmp/dumps/crash_20230805155035_26.dmp’', upload yes: ‘‘CrashID=bp-3e28991f-2355-476d-987e-2156e2230805’’
/home/fisqs/.local/share/Steam/steam.sh: linia 798: 6266 Przerwane (zrzut pamięci) “$STEAMROOT/$STEAMEXEPATH” “$@”
Moja magiczna komenda
LD_PRELOAD=‘/usr/$LIB/libstdc++.so.6 /usr/$LIB/libgcc_s.so.1 /usr/$LIB/libxcb.so.1 /usr/$LIB/libgpg-error.so’ /usr/bin/steam
Też nie działa ;/
