[Stable Update] 2021-08-27 - Kernels, Cutefish, NetworkManager, Gnome, Pamac,
Nowa aktualizacja na początek weekendu. Czas na imprezkę z aktualizacją w tle :crazy_face:
No właśnie wyskoczył news. Ktoś już coś, na ten temat? Nie chciał bym, aby się mój sterownik przeklętej nvidii, wypiął na mnie :smiley:
### Nvidia card owners
* We simplified **nVidia** driver installation. This means we [dropped legacy drivers](https://forum.manjaro.org/t/36338).
  * We recommend to switch over to **Nouveau** drivers if your card is mentioned [here](https://nouveau.freedesktop.org/CodeNames.html) and the feature you need is not in red <kbd>TO DO</kbd> [here](https://nouveau.freedesktop.org/FeatureMatrix.html) for your particular card.
  * If you however still need proprietary drivers, you may want to execute the following to ensure all parts of the **nVidia** drivers get installed properly:
sudo mhwd -a pci nonfree 0300
If proprietary drivers don't fix everything, please click the ► at the beginning of this line to view more info
1. try installing kernel 5.4 LTS (Long Term Support)
2. If that doesn’t fix it, [take a full system backup](https://forum.manjaro.org/t/howto-make-a-crash-proof-backup-for-manjaro/3970), go to a console using <kbd>Ctrl</kbd>+<kbd>Alt</kbd>+<kbd>F2</kbd> and:
* Backup `/etc/X11/mhwd.d/nvidia.conf` if you ever edited that manually
* remove all nVidia related drivers and applications:
pacman --remove nvidia*
* Note which applications are being removed and keep them handy in a list
* Install the driver first:
mhwd --install video-hybrid-XXX-nvidia-prime
(Where `XXX` is `amd` or `intel` if you have hybrid graphics or the whole thing is `video-nvidia` if you’re on an nVidia-only system)
* reboot and see if you at least get a screen.
* Install all the other applications from your handy list *that you still need* one by one.
* Restore `/etc/X11/mhwd.d/nvidia.conf` if you ever edited that manually
* If that wouldn’t solve the issue open a new issue [here](https://forum.manjaro.org/c/support/Graphic-Cards/33) referring to this update and posting at a minimum the full output of:
inxi --admin --verbosity=7 --filter --no-host --width
If you however still have issues with your **Nvidia** card, you may open a new thread in our forum: [Graphics & Display - Manjaro Linux Forum](https://forum.manjaro.org/c/support/Graphic-Cards/33) or look at our [tutorial on compiling old Nvidia drivers](https://forum.manjaro.org/t/support-how-to-2020-12-30-update-broke-my-system-with-nvidia-proprietary-drivers/46071).
Widzę, kilka błędów może wystąpić, nie tylko z nvidią. Dzięki Panowie za wszelkie podpowiedzi. BTW używam kernela, w wersji 5.4
Informacja o NVIDIA i opis potencjalnych problemów jest sprzed paru miesięcy, jeśli wykonywałeś ostatnio aktualizacje to już byś się ewentualnie natknął na ten problem.
Zatem jedziem z tym koksem :smiley: W końcu problemy są po to, by je rozwiązywać :slight_smile:
I tyleśmy kolegę z forum widzieli? :wink:
@napcok spoko, wszystko gra :slight_smile: Dzięki za troskę :stuck_out_tongue: Poszło gładko i wszystko aktualne. Ale nazbierało się kilka pytań, przemyśleń, więc i tematów trochę przybędzie, ino wena nadejść musi. Pozdrówka dla Wszystkich!!!
