Przy uruchomieniu całkowity brak reakcji/błędu jedynie w konsoli można coś zobaczyć.
Starting app 233450
Installing breakpad exception handler for appid(steam)/version(1575604565)
Adding process 12751 for game ID 233450
GameAction [AppID 233450, ActionID 1] : LaunchApp changed task to WaitingGameWindow with “”
ERROR: ld.so: object ‘/home/pablo/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so’ from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
GameAction [AppID 233450, ActionID 1] : LaunchApp changed task to Completed with “”
Adding process 12752 for game ID 233450
Adding process 12754 for game ID 233450
Adding process 12755 for game ID 233450
Adding process 12756 for game ID 233450
/usr/lib/gvfs/libgvfscommon.so: undefined symbol: g_task_new
Failed to load module: /usr/lib/gio/modules/libgvfsdbus.so
Adding process 12757 for game ID 233450
pressure-vessel-locale-gen: No locales need to be generated
Adding process 12873 for game ID 233450
Adding process 12874 for game ID 233450
Adding process 12880 for game ID 233450
Game removed: AppID 233450 “”, ProcID 12751
Uploaded AppInterfaceStats to Steam
Exiting app 233450
No cached sticky mapping in ActivateActionSet.[1216/091139.857066:INFO:crash_reporting.cc(270)] Crash reporting enabled for process: renderer
[1216/091139.928820:INFO:crash_reporting.cc(270)] Crash reporting enabled for process: renderer
[1216/091142.666980:WARNING:crash_reporting.cc(286)] Failed to set crash key: UserID with value: 0
[1216/091142.667078:WARNING:crash_reporting.cc(286)] Failed to set crash key: BuildID with value: 1575603249
[1216/091142.667092:WARNING:crash_reporting.cc(286)] Failed to set crash key: SteamUniverse with value: Public
[1216/091142.667103:WARNING:crash_reporting.cc(286)] Failed to set crash key: Vendor with value: Valve
[1216/091142.667063:WARNING:crash_reporting.cc(286)] Failed to set crash key: UserID with value: 0
[1216/091142.667156:WARNING:crash_reporting.cc(286)] Failed to set crash key: BuildID with value: 1575603249
[1216/091142.667172:WARNING:crash_reporting.cc(286)] Failed to set crash key: SteamUniverse with value: Public
[1216/091142.667186:WARNING:crash_reporting.cc(286)] Failed to set crash key: Vendor with value: Valve
[1216/091142.667892:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: utility
