Pokaż swoje Conky - i podziel się konfiguracją
Pewnie wszyscy widzieli - prosty config.
own_window yes
own_window_type normal
own_window_transparent yes
own_window_hints undecorated,below,sticky,skip_taskbar,skip_pager
own_window_colour 000000
own_window_class Conky
own_window_title Mabox Monitor Conky
gap_x 15
gap_y 50
alignment tr
minimum_width 200
minimum_size 200
use_xft yes
xftfont Cantarell:size=9
xftalpha 1
override_utf8_locale yes
draw_shades no #yes
default_shade_color 000000
draw_outline no
default_outline_color 000000
color2 777777
cpu_avg_samples  2
default_color FFFFFF
draw_borders no #yes
stippled_borders 5
border_inner_margin 5
border_outer_margin 0
border_width 2
background yes
no_buffers yes
imlib_cache_size 0
double_buffer yes
update_interval 1
TEXT
${voffset 8}$color${font Cantarell:size=16}${time %A}$font${voffset -18}$alignr${color 006600}${font Cantarell:size=38}${time %e}$font
$color${voffset -20}$color${font Cantarell:size=18}${time %B}$font${voffset -1} $color${font Cantarell:size=20}${time %Y}$font
${voffset 10}${goto 40}${color}CPU$alignr$cpu%
$color2${goto 40}$alignr${cpubar 4,165}
${voffset 5}${goto 40}$font$color2${top name 1}$alignr$color${top cpu 1}%
${goto 40}$color2${top name 2}$alignr$color${top cpu 2}%
${goto 40}$color2${top name 3}$alignr$color${top cpu 3}%
${goto 40}$color2${top name 4}$alignr$color${top cpu 4}%
${voffset 10}${goto 40}${color}RAM$alignr$mem/$memmax
$color2${goto 40}$alignr${membar 4,165}
${goto 40}${voffset 5}$color2${top_mem name 1}$alignr$color${top_mem mem_res 1}
${goto 40}$color2${top_mem name 2}$alignr$color${top_mem mem_res 2}
${goto 40}$color2${top_mem name 3}$alignr$color${top_mem mem_res 3}
${goto 40}$color2${top_mem name 4}$alignr$color${top_mem mem_res 4}
${voffset 10}$alignr dysk ${color2}${fs_used /} - ${fs_size /}
$alignr$color pamięć ${color2}$mem - $memmax
#${alignr}${color2}${font Cantarell:size=9}swap $swapmax - $swap
${voffset 10}$alignr${color} Mabox Linux ${execi 10000 awk -F'=' '/DISTRIB_RELEASE=/ {printf $2" "} /CODENAME/ {print $2}' /etc/lsb-release}
${voffset 10}$alignr${execi 1200 whoami}@${nodename}
${alignr}${color2}${font Cantarell:size=9}uptime ${color}${uptime_short}
${alignr}${color2}${font Cantarell:size=9}${alignr}jądro ${color}${kernel}
${alignr}${color2}${font Cantarell:size=9}${alignr}arch ${color}${machine}
${alignr}${color2}${font Cantarell:size=9}${alignr}system plików ${color}${fs_type}
${voffset 10}${alignr}${color} dostępne aktualizacje ${color 006600}${font Cantarell:bold:size=10}${execpi 10800 checkupdates | wc -l}${font}${color}
${alignr}${color} zainstalowane pakiety: ${color2}${execi 10000 pacman -Q | wc -l}
Mój config conky także nie jest zbytnio skomplikowany.
xftfont Bold:size=9
xftalpha 0.1
text_buffer_size 2048
# Update interval in seconds
update_interval 1
# This is the number of times Conky will update before quitting.
# Set to zero to run forever.
total_run_times 0
# Create own window instead of using desktop (required in nautilus)
own_window yes
own_window_argb_visual yes
# When ARGB visuals are enabled, use this to modify the alpha value used.
# Valid range is 0-255, where 0 (zero) is 0% opacity, and 255 is 100% opacity.
own_window_argb_value 0
own_window_type panel
own_window_type desktop
own_window_hints undecorated,sticky,below,skip_taskbar,skip_pager
# Use double buffering (reduces flicker, may not work for everyone)
double_buffer yes
# Minimum size of text area
minimum_size 300 300
maximum_width 300
# Draw shades?
draw_shades no
# Draw outlines?
draw_outline no
# Draw borders around text
draw_borders no
# Stippled borders?
stippled_borders 0
# Border margins
#border_margins 5
# Border width
border_width 1
# Default colors and also border colors
default_color 0A960F
default_shade_color 0A960F
default_outline_color 0A960F
#default_color d8d8d8
color1 0998ED
color2 C37D0E
color3 0EB3C3
# Text alignment, other possible values are commented
#alignment top_left
#alignment top_right
#alignment bottom_left
alignment top_right
# Gap between borders of screen and text
#same thing as passing -x at command line
gap_x 5
gap_y 0
# Subtract file system buffers from used memory?
no_buffers yes
# Set to yes if you want all text to be in uppercase
uppercase no
# Number of cpu samples to average
#set to 1 to disable averaging
cpu_avg_samples 1
# Number of net samples to average
net_avg_samples 1
# Force UTF8? note that UTF8 support required XFT
# Add spaces to keep things from moving about?  This only affects certain objects.
use_spacer none
TEXT
#${alignr}${font Ubuntu:pixelsize=26}${desktop}${font}
# SYSTEM #
${voffset -15}${image /home/robson/.conky/Logo.png -p 0,0 -s 38x38}${image /home/robson/.conky/Logo.png -p 260,0 -s 38x38}
${color3}${font Roboto Black:size=20}$alignc${time %H:%M:%S}
${voffset -15}${font Roboto Black:size=14}$alignc${time %A} ${time %d} ${time %B} ${time %Y}
${color1}${voffset -12}${font Roboto Black:size=9}${scroll 44 2 ${execi 1200 whoami}@${nodename}-$sysname $kernel $machine}
${voffset 0}${font Roboto Black:size=10}${color2}SYSTEM $color$font Arch  Xfce                                 ${execi 10000 awk -F'=' '/DISTRIB_RELEASE=/ {printf $2" "} /CODENAME/ {print $2}' /etc/lsb-release}
${voffset -4}${font Play :Bold:size=11}$sysname kernel: $font$kernel$alignr$machine
${voffset -4}${font Play :Bold:size=11}Czas działania: $font$alignr$uptime
${voffset -4}${font Play :Bold:size=11}Temperatura gpu: $font$alignr${execi 30 sensors | grep 'temp1:' | cut -c16-19}${color0}°C
${voffset -4}${font Play :Bold:size=11}${color}Pakiety do aktualizacji: $font${alignr 8}${color1}${execpi 80 checkupdates | wc -l}${color}
${voffset -4}${font Play :Bold:size=11}Pakiety zainstalowane: $font$alignr${execi 20 pacman -Q | wc -l}
${voffset -4}${font Play :Bold:size=11}Ostatnia aktualizacja: $font$alignr${voffset 1}${execi 20 grep "starting full system upgrade" /var/log/pacman.log | tail -n1| cut --bytes=2-17}
# CPU #
${voffset -3}${font Roboto Black:size=10}${color2}CPU${color}${font} Intel Core 4x i3-2100 CPU@3.10GHz $acpitemp${color0}°C
#Core 1 - ${execi 2 sensors | grep 'Core 1' | cut -c17-20}°C ${alignc 60}${cpubar cpu1}${color}
#Core 2 - ${execi 2 sensors | grep 'Core 2' | cut -c17-20}°C ${alignc 60}${cpubar cpu2}${color}
${alignc 30}${voffset -5}${cpugraph 1 20,148 0000ff 00ff00 -t}${alignr}${cpugraph 2 20,148 0000ff 00ff00 -t}
${color0}${alignc 50}${voffset -10}${cpubar cpu1 5,148}${alignr}${cpubar cpu2 5,148}
${alignc 30}${voffset -6}${color}${font Play :Bold:size=11}Core 1 $font${cpu cpu1}% ${alignr 30}${voffset -3}${font Play :Bold:size=11}Core 2 $font${cpu cpu2}%
${font Roboto Black:size=10}${color2}USAGE${font Roboto Black:size=10}${color2}${alignr 48}RAM${color2}${alignr 18}${font Roboto Black:size=10}CPU
${font :Bold:size=10}${color1}${top name 1}${voffset -3}$font$alignr${top cpu 1} %
${voffset -16}$alignr${voffset 2}${offset -60}${top mem 1} %
${font :Bold:size=10}${top name 2}${voffset -3}$font$alignr${top cpu 2} %
${voffset -16}$alignr${voffset 2}${offset -60}${top mem 2} %
${font :Bold:size=10}${top name 3}${voffset -3}$font$alignr${top cpu 3} %
${voffset -16}$alignr${voffset 2}${offset -60}${top mem 3} %
${font :Bold:size=10}${top name 4}${voffset -3}$font$alignr${top cpu 4} %
${voffset -16}$alignr${voffset 2}${offset -60}${top mem 4} %
${font :Bold:size=10}${top name 5}${voffset -3}$font$alignr${top cpu 5} %
${voffset -16}$alignr${voffset 2}${offset -60}${top mem 5} %
${font :Bold:size=10}${top name 6}${voffset -3}$font$alignr${top cpu 6} %
${voffset -16}$alignr${voffset 2}${offset -60}${top mem 6} %
# MEMORY #
${voffset 0}${font Roboto Black:size=10}${color2}MEMORY $font${color}$memperc% ${color0}${membar 5}
${voffset -10}${color}$hr
${color}${font Play :Bold:size=11}${voffset -7}Used: $font$mem of $memmax$alignr${font Play :Bold:size=11}${voffset -3}Free: $font$memeasyfree$alignr
${font Play :Bold:size=11}${voffset -2}Buffer: $font$buffers$alignr${font Play :Bold:size=11}${voffset -4}Cache: $font$cached$alignr
${voffset -15}${color}${voffset 5}$hr
${font :Bold:size=10}${color1}${top_mem name 1}$font$alignr${top_mem mem_res 1}
${voffset -17}${alignr}
${font :Bold:size=10}${top_mem name 2}$font$alignr${top_mem mem_res 2}
${font :Bold:size=10}${top_mem name 3}$font$alignr${top_mem mem_res 3}
${font :Bold:size=10}${top_mem name 4}$font$alignr${top_mem mem_res 4}
${font :Bold:size=10}${top_mem name 5}$font$alignr${top_mem mem_res 5}
${font :Bold:size=10}${top_mem name 6}$font$alignr${top_mem mem_res 6}
# HDD #
${voffset 0}${font Roboto Black:size=10}${color2}DISC ${color}$font sda: ${execi 3600 cat /sys/block/sda/device/model || echo "none"} ${if_match "${hddtemp /dev/sda}"<="40" }${color 0A960F}$else${if_match "${hddtemp /dev/sda}"<="50" }${color orange}$else${color red}${font :Bold:size=10}UWAGA! $endif$endif${hddtemp /dev/sda}${color0}°C ${voffset 0}${alignr}${diskiograph /dev/sda 8,60 F57900 FCAF3E}
#home
${color}${voffset -3}${font Play :Bold:size=11}Home used: (${fs_type /}) $font${fs_used /} of ${fs_size /} ${color}  ${fs_used_perc /} % ${color0}
#boot
${color}${voffset -3}${font Play :Bold:size=11}Boot used: (${fs_type /boot/}) $font${fs_used /boot/} of ${fs_size /boot/} ${color}  ${fs_used_perc /boot/} % ${color0}
$color${voffset -3}${font Play :Bold:size=11}write: $font${diskio_write /dev/sda}${alignc}${voffset -4}${font Play :Bold:size=11}read: $font${diskio_read /dev/sda}
#swap
${voffset -3}${font Play :Bold:size=11}Swap used: $font$swap of $swapmax ${color}$alignr$swapperc% ${color0}${swapbar 7,60}
# NETWORK #
${voffset 0}${font Roboto Black:size=10}${color2}NETWORK ${execpi 4 echo "\${font}\${color} (ping: \${font Roboto Black:size=10}\${color #66aaff}$(ping -W 1 -c 1 8.8.8.8 -q | grep rtt | egrep [0-9]+\.[0-9]+ -o | head -n 2 | tail -n 1)\${font}\${color} ms"})
${voffset -4}${color1}${font Roboto Black:size=10}External IP ${font}${alignr}${execi 10600  curl -s www.icanhazip.com}
#Wykrywanie karty sieciowej
${voffset 2}${color}Network connected $hr
${if_existing /proc/net/route enp0s26u1u2}
${voffset -28}${font}${alignr}
${color}↓Pobrane: ${downspeedf enp0s26u1u2} kB/s $alignr${totaldown enp0s26u1u2}
${voffset -14}${alignc -40}${color0}${downspeedgraph enp0s26u1u2 8,85 000000 aaddff}
${color}↑Wysłane: ${upspeedf enp0s26u1u2} kB/s $alignr${totalup enp0s26u1u2}
${voffset -14}${alignc -40}${color0}${upspeedgraph enp0s26u1u2 8,85 000000 aaddff}
${else}${if_existing /proc/net/route enp0s26u1u2}
${voffset -14}${alignc -40}${color0}${downspeedgraph enp0s26u1u2 8,85  000000 66aaff}
${endif}${endif}${endif}
#Koniec wykrywania karty sieciowej
${voffset -25}${color}$hr
I jeszcze pytanie do admina, jak na tym forum się dodaje znaczniki code.
Znaczniki code dodajemy za pomocą trzech znaków ```
na początku i na końcu.
Generalnie w edytorze działa markdown.
Tutaj masz wprowadzenie do markdown → Wstęp | Poznaj Markdown
jak się chwalą to ja też :wink:
configów za dużo coby wstawiać ale tutaj są:
Małe skromne, ale własne
# WINDOW
own_window yes
own_window_transparent no
own_window_hints undecorated,below,skip_taskbar,skip_pager,sticky
own_window_argb_value 60
#own_window_class Conky
own_window_title Weater Conky
gap_x 55
gap_y 85
#minimum_width 250
minimum_size 250 0  ### w|h
alignment top_right
# FONTS
use_xft yes
xftalpha 1
xftfont Monospace:size=11
# COLORS
draw_shades no #yes
draw_outline no
#default_color 656667 # Waldorf original colour
#default_color 7a7a7a # Flame  & Bunsen Grey
#default_color 929292 # Labs Grey
#default_color C0C0C0 # Silver
#default_color FFFFFF
color0 B0E0E6 # PowderBlue
color1 778899 # LightSlateGray
#color2 D8BFD8 # Thistle
color2 FFFFFF
color3 9ACD32 # YellowGreen
color4 FFA07A # LightSalmon
color5 FFDEAD # NavajoWhite
color6 00BFFF # DeepSkyBlue
color7 5F9EA0 # CadetBlue
color8 BDB76B # DarkKhaki
color9 000000 # IndianRed
# BORDERS
# Stippled borders?
stippled_borders 5
# border margins
border_inner_margin 15
border_outer_margin 15
# border width
border_width 2
# graph borders
# draw_graph_borders yes
# default_graph_size 15 40
# MISC
# Boolean value, if true, Conky will be forked to background when started.
background no
# Adds spaces around certain objects to stop them from moving other things
# around, this only helps if you are using a mono font
# Options: right, left or none
use_spacer none
# Subtract (file system) buffers from used memory?
no_buffers yes
# Imlib2 image cache size, in bytes. Default 4MiB Increase this value if you use
# $image lots. Set to 0 to disable the image cache.
imlib_cache_size 0
# Use the Xdbe extension? (eliminates flicker)
# It is highly recommended to use own window with this one
# so double buffer won't be so big.
double_buffer yes
update_interval 1.0
TEXT
${color2}${texeci 1800 curl pl.wttr.in/radomsko?0 | sed -n '3,7{s/\d27\[[0-9;]*m//g;s/^..//;s/ *$//;p}'}
${alignc}S Y S T E M    I N F O
${membar 0}
${color0}Host:${alignr}${nodename}
Uptime:${alignr}${uptime}
${color3}RAM:$alignr${mem} / ${memmax}
${goto 40}$alignr${membar 5,170}
${color4}CPU:${alignr}${cpu cpu0}%
${goto 40}$alignr${cpubar 5,170}
CPU 1:${alignr}${hwmon 0 temp 1}°C
CPU 2:${alignr}${hwmon 1 temp 1}°C
CPU 3:${alignr}${hwmon 2 temp 1}°C
${alignc}${color2}D I S K
${membar 0}
${color6}Root:$alignr${fs_used /} / ${fs_size /}
Home:$alignr${fs_used /home} / ${fs_size /home}
Disk1:${alignr}${fs_used /run/media/ulther/DATA} / ${fs_size /run/media/ulther/DATA}
Disk2:${alignr}${fs_used /run/media/ulther/DATA2} / ${fs_size /run/media/ulther/DATA2}
@UltherEgo fajna sprawa z wykorzystaniem wttr.in do pokazania info o pogodzie :slight_smile:
Jeśli ktoś chce widzieć w Conky ilość dostępnych aktualizacji, a używa Pamac to podaję zaklęcia:
  1. Tylko paczki z repozytoriów:
${execpi 1800 pamac checkupdates -q | wc -l}
  1. Również dostępne aktualizacje z AUR:
${execpi 1800 pamac checkupdates -aq | wc -l}
W obu przypadkach sprawdzanie odbywa się co 30 minut (1800 sekund).
A jeszcze nie wiem jak przesłac config. Przydałaby się prosta instrukcja.Już dawno nie udzelałem się aktywnie na forum. Awszystko ewouluje.
Ja też miałem problem z dodawaniem znaczników code, ale @napcok mi wyjaśnił jak to się robi.
A więc musisz dodać takie znaki ``` 3 na początku i 3 na końcu, (klawiszem nad Tab-em), a pomiędzy nimi wklejasz zawartość.
A ja z tego co wrzuciliście tutaj, zrobiłem Coś swojego :slight_smile:
own_window yes
gap_x 15
gap_y 15
#minimum_width 250
minimum_size 0 0
alignment top_right
# FONTS
use_xft yes
xftalpha 1
# COLORS
draw_shades no #yes
draw_outline no
color2 FFFFFF
# BORDERS
# Stippled borders?
stippled_borders 5
# border margins
# border width
border_width 2
# graph borders
# MISC
background no
use_spacer none
no_buffers yes
imlib_cache_size 0
double_buffer yes
update_interval 1.0
TEXT
${color2}${texeci 1800 curl http://pl.wttr.in/Wlodawa | sed -n '3,7{s/\d27\[[0-9;]*m//g;s/^..//;s/ *$//;p}'}
${color6}${hr 2}${font xos4 Terminus::size=10}
${alignc}Manjaro Linux XFCE
${color4}${alignc} Prosta, elegancka dystrybucja
${color0}Władca:${alignr}${nodename}
Pracę od:${alignr}${uptime}
CPU 2:${alignr}${hwmon 2 temp 1}°C
${color4}Procesor i pamięć ${color6}${hr 2}
${color1}Użycie procesora  ${color0}${alignc} ${cpubar 3,81} ${alignr} ${color1}$cpu% @ ${freq_g cpu}GHz
${color1}Core1:  ${color0}${cpubar cpu0 3,55}  ${color1}${cpu cpu0}% ${alignr}${color1}${cpu cpu2}%  ${color0}${cpubar cpu2 3,55}${color1}  :Core3
${color1}Core2:  ${color0}${cpubar cpu1 3,55}  ${color1}${cpu cpu1}% ${alignr}${color1}${cpu cpu3}%  ${color0}${cpubar cpu3 3,55}${color1}  :Core4
${color6}${hr 2}${font xos4 Terminus::size=9}
${color1}${alignc}Temperatura:${color4} CPU: ${color1}${hwmon 0 temp 1}°C${color4}
${alignc}${color2}PAMIĘĆ MASOWA
${color4}Dysk C:
${color4}Linux: ${color1} (${fs_type})    ${alignc}${color1}${fs_size /} > ${color1}${fs_used /}${color0} ${alignr}${fs_bar 3,50} ${color6}(${fs_used_perc /}%)
Dysk SSD:$alignr${fs_used /home} / ${fs_size /home}
${color4}Dysk Zapis-> ${alignc}${color2}${diskio_read}/s ${alignr}${color2}${diskio_write}/s ${color4}<-Dysk Odczyt
${color6}${diskiograph_read 15,140 000000 95a3ab} ${alignr}${color6}${diskiograph_write 15,140 000000 434745}$color
${alignr}${color} zainstalowane pakiety: ${color2}${execi 10000 pacman -Q | wc -l}}
${alignr}${color2}${font Cantarell:size=9}${alignr}jajko ${color}${kernel}
${alignr}${color2}${font Cantarell:size=9}${alignr}manjaro ${color}${machine}
I o to chodziło .Dzięki! Trudno nie zrozumieć. Teraz jestem pewien, że całeść trzeba zamknąć “kodami”. A tak przy okazji dobrze by było wstawić instrukcje dla “zielonych” by forum było PRZYJAZNE.
Jest opisane tutaj
Zmieniłem swój config conky ze składni 1.9 na 1.10
conky.config = {
-- Conky settings --
    update_interval = 1,
    total_run_times = 0,
    background = true,
    cpu_avg_samples = 1,
    net_avg_samples = 1,
    override_utf8_locale = true,
    double_buffer = true,
    no_buffers  = true,
    text_buffer_size = 256,
    imlib_cache_size = 10,
    format_human_readable = true,
-- Window specifications --
    own_window = true,
    own_window_type = 'normal',
    own_window_transparent = true,
    own_window_argb_visual = true,
    own_window_argb_value = 30,
    own_window_hints = 'undecorated,sticky,below,skip_taskbar,skip_pager',
--    own_window_colour = '#484B52',
    maximum_width = 300,
    alignment = 'top_right',
    gap_x = 0,
    gap_y = 20,
-- Graphics settings --
    draw_shades = false,
    draw_outline = false,
    draw_borders = false,
    draw_graph_borders = true,
    border_width = 0,
-- Text settings --
    use_xft = true,
    font = 'Bold:size=9',
    xftalpha = 0.5,
-- Color settings -,
    default_color = '0A960F',
    color1 = '0998ED',
    color2 = 'C37D0E',
    color3 = '0EB3C3',
conky.text = [[
# SYSTEM #
${voffset 0}${font Roboto Black:size=10}${color2}SYSTEM $color$font Arch Linux Xfce                         ${execi 10000 awk -F'=' '/DISTRIB_RELEASE=/ {printf $2" "} /CODENAME/ {print $2}' /etc/lsb-release}
${voffset -4}${font Play :Bold:size=11}${color}Paczki do aktualizacji: $font${alignr 8}${color1}${execpi 80 checkupdates | wc -l}${color}
${voffset -4}${font Play :Bold:size=11}Paczki zainstalowane: $font$alignr${execi 10 pacman -Q | wc -l}
${voffset -4}${font Play :Bold:size=11}Ostatnia aktualizacja: $font$alignr${voffset 1}${execi 10 grep "starting full system upgrade" /var/log/pacman.log | tail -n1| cut --bytes=2-17}
# CPU #
${font Roboto Black:size=10}${color2}USAGE${font Roboto Black:size=10}${color2}${alignr 47}RAM${color2}${alignr 18}${font Roboto Black:size=10}CPU
# MEMORY #
# HDD #
#home
${color}${voffset -3}${font Play :Bold:size=11}Home used: (${fs_type /}) $font${fs_used /} of ${fs_size /} ${color} ${fs_used_perc /}% ${color0}
#boot
${color}${voffset -3}${font Play :Bold:size=11}Boot used: (${fs_type /boot/}) $font${fs_used /boot/} of ${fs_size /boot/} ${color}  ${fs_used_perc /boot/}% ${color0}
$color${voffset -3}${font Play :Bold:size=11}write: $font${diskio_write /dev/sda2}${alignc}${voffset -4}${font Play :Bold:size=11}read: $font${diskio_read /dev/sda2}
#swap
${voffset -3}${font Play :Bold:size=11}Swap used: $font$swap of $swapmax ${color}$alignr$swapperc% ${color0}${swapbar 8,60}
# NETWORK #
${voffset 0}${font Roboto Black:size=10}${color2}NETWORK ${execpi 4 echo "\${font}\${color} (ping: \${font Roboto Black:size=10}\${color #66aaff}$(ping -W 1 -c 1 192.168.8.1 -q | grep rtt | egrep [0-9]+\.[0-9]+ -o | head -n 2 | tail -n 1)\${font}\${color} ms"})
${if_existing /proc/net/route enp0s26u1u3}
${color}↓Pobrane: ${downspeedf enp0s26u1u3} kB/s $alignr${totaldown enp0s26u1u3}
${voffset -14}${alignc -40}${color0}${downspeedgraph enp0s26u1u3 8,85 000000 66aaff}
${color}↑Wysłane: ${upspeedf enp0s26u1u3} kB/s $alignr${totalup enp0s26u1u3}
${voffset -14}${alignc -40}${color0}${upspeedgraph enp0s26u1u3 8,85 000000 66aaff}
${else}${if_existing /proc/net/route enp0s26u1u3}
${voffset -14}${alignc -40}${color0}${upspeedgraph enp0s26u1u3 8,85  000000 aaddff}
${color}${texeci 120 curl -s pl.wttr.in/Szczecin?0 | sed -n '3,7{s/\d27\[[0-9;]*m//g;s/^..//;s/ *$//;p}'}
Albo pobrać można stąd
http://wrzucplik.pl/pokaz/1779907---agci.html
Konfiguracja
background yes
use_xft yes
xftfont sans:size=11
xftalpha 1
update_interval 1.0
total_run_times 0
own_window yes
double_buffer yes
minimum_size 300 1
maximum_width 600
draw_shades no
draw_outline no
draw_borders no
draw_graph_borders no
default_color Black
default_outline_color d9d7d6
alignment tr
gap_x 12
gap_y 70
no_buffers yes
uppercase no
cpu_avg_samples 2
TEXT
${font sans:bold:size=18}${alignr}${color #77E110}${time %e} ${color #BEBEBE}${time %B}${color #77E110} ${time %Y}${color #BEBEBE}
${alignr}${font sans:bold:size=15}${time %X}${voffset -8}
${color #BEBEBE}${hr 1}${voffset -4}
${font sans:bold:size=9}${alignr}${color #77E110}Host: ${color #BEBEBE}${alignr}${nodename}
${font sans:bold:size=9}${alignr}${color #77E110}RAM: ${color #BEBEBE}$mem / $memmax
${font sans:bold:size=9}${alignr}${color #77E110}CPU 1: ${color #BEBEBE}${cpu cpu0}% - ${color #77E110}CPU 2: ${color #BEBEBE}${cpu cpu1}%
${font sans:bold:size=9}${alignr}${color #77E110}CPU 3: ${color #BEBEBE}${cpu cpu2}% - ${color #77E110}CPU 4: ${color #BEBEBE}${cpu cpu3}%
${font sans:bold:size=9}${alignr}${color #77E110}Uptime: ${color #BEBEBE}$uptime_short
${font sans:bold:size=9}${alignr}${color #77E110} dostępne aktualizacje: ${color #BEBEBE}${execpi 300 checkupdates | wc -l}
${font sans:bold:size=9}${alignr}${color #77E110}Gmail: ${color #BEBEBE}${execi 300 ~/bin/mail/gmail.py}
${font sans:bold:size=9}${alignr}${color #77E110}Hotmail: ${color #BEBEBE}${execi 300 ~/bin/mail/hotmail.py}
${font sans:bold:size=9}${voffset 10}${alignr}${color #77E110}Uptime SERVER: ${color #BEBEBE}${execi 10800 ssh XX.XXX.XXX "uptime | sed 's/.*up \([^,]*\), .*/\1/'"}
${font sans:bold:size=9}${alignr}${color #77E110}dostępne aktualizacje na SERVERZE: ${color #BEBEBE}${execi 10800 ssh XX.XXX.XX "yum check-update --quiet | grep -v "^$" | wc -l"}
${color d9d7d6}${hr 1}${voffset 6}
${if_running spotify}\
	${voffset -160}
	${image ~/bin/spotify/spotify_icon.png -p 0,255 -s 50x50}
	${color #77E110}${alignr}${voffset 130}${font sans:bold:size=9}${exec ~/bin/spotify/artist.sh}${font}
	${color #BEBEBE}${alignr}${font sans:bold:size=9}${exec ~/bin/spotify/title.sh}${font}
${endif}\
Skrypt sprawdzający ilość maili nieprzeczytanych
~/bin/mail/gmail.py
#!/usr/bin/env python3
import imaplib
IMAPSERVER = 'imap.xxx.com'   #imap poczty (gmail, outlook, etc.)
USER = 'login'
PASSWORD = 'hasło'
mail = imaplib.IMAP4_SSL(IMAPSERVER)
mail.login(USER, PASSWORD)
mail.select("inbox", True) # connect to inbox.
return_code, mail_ids = mail.search(None, 'UnSeen')
count = len(mail_ids[0])
print(count)
Spotyfi indicator
Tutaj będą potrzebne 2 pliki + ikonka
Ikonka
Plik artist.sh
#!/bin/bash
artist=`dbus-send --print-reply --dest=org.mpris.MediaPlayer2.spotify /org/mpris/MediaPlayer2 org.freedesktop.DBus.Properties.Get string:'org.mpris.MediaPlayer2.Player' string:'Metadata'|egrep -A 2 "artist"|egrep -v "artist"|egrep -v "array"|cut -b 27-|cut -d '"' -f 1|egrep -v ^$`
echo $artist
Plik title.sh
#!/bin/bash
title=`dbus-send --print-reply --dest=org.mpris.MediaPlayer2.spotify /org/mpris/MediaPlayer2 org.freedesktop.DBus.Properties.Get string:'org.mpris.MediaPlayer2.Player' string:'Metadata'|egrep -A 1 "title"|egrep -v "title"|cut -b 44-|cut -d '"' -f 1|egrep -v ^$`
echo $title
Całosć: https://github.com/UltherEgo/ConkyMantis
Postawiłem na minimalizm
conky.config = {
-- Simple Bar Conky Theme V. 0.1 - by mrmaire <maire.nunez@gmail.co>
-- Minimalist theme for conky
use_xft = true,
font = 'play:bold:size=7',
xftalpha = 0.1,
update_interval = 3,
own_window = true,
own_window_transparent = false,
own_window_hints = 'undecorated,below,sticky,skip_taskbar,skip_pager',
own_window_colour = '#20252E',
own_window_argb_value = 192,
draw_graph_borders = false,
default_color = 'white',
default_shade_color = 'red',
default_outline_color = 'green',
alignment = 'top_middle',
gap_x = 0,
gap_y = 45,
no_buffers = true,
uppercase = false,
cpu_avg_samples = 2,
use_spacer = 'right',
conky.text = [[
${color cbcbcb}System:${color 17ba9d} ${execi 60 lsb_release -ds | awk '{print $1}'} ${execi 60 lsb_release -ds | awk '{print $2}'} ${execi 60 lsb_release -ds | awk '{print $3}'} ${execi 60 lsb_release -cs | awk '{print $1}'}  ($machine) ${color a6e22e} | ${color cbcbcb}Computer:${color fd971f} $nodename ${color a6e22e}| ${color cbcbcb}Time: ${color 20a5e4}${time %I:%M:%S} ${color a6e22e}| ${color cbcbcb}Date: ${color 20a5e4}${time %a}, ${time %d} ${time  %B} ${time %Y} ${color a6e22e}| ${color cbcbcb} Uptime: ${color fd971f} $uptime ${color a6e22e}| ${color cbcbcb}Processes: ${color fd971f}${processes} / ${running_processes} ${color a6e22e}| ${color cbcbcb}Kernel:${color #17ba9d} $kernel ${color a6e22e}| ${color 9e6ffe}CPU: ${color d3d3d3}${cpu}% / ${color D45959}${hwmon temp 1}°C ${color a6e22e}| ${color cbcbcb}RAM: ${color fd971f}$memperc% ${color a6e22e}| ${color D45959}Root: ${color e0e0e0}${fs_free /} / ${fs_size /} ${color a6e22e}| ${color 20a5e4}Home: ${color e0e0e0}${fs_free /home} / ${fs_size /home} ${color a6e22e}|  ${color a6e22e} UP: ${color cbcbcb}${downspeedgraph enp2s0 8,60 black black} | ${color D45959} Down: ${color cbcbcb}${upspeedgraph enp2s0 8,60 black black} ${color #a6e22e}| ${color cbcbcb}Nvidia: ${color 20a5e4} ${execi 5 nvidia-settings -q [gpu:0]/UsedDedicatedGPUMemory -t} / ${exec nvidia-settings -q [gpu:0]/TotalDedicatedGPUMemory -t} MiB ${alignr}${color D45959}${nvidia temp} °C
Moje po niewielkich przeróbkach kolorystycznych
kosmetyczne zmiany:
config standardowo:
@LinGruby wstawiłem do swojego conky linię z pogodą (z conky twego) ale nie odświeża mi na bieżąco. Coś tam może dopisać?
To ta linijka
${alignc}${color}${font Hack:size=9:weight=bold}${texeci 1200 curl -s 'https://pl.wttr.in/Vichy?0' | sed -n '2,7{s/\d27\[[0-9;]*m//g;s/^..//;s/ *$//;p}'}
1200 co tyle sekund powinno się odświeżać nic innego nie odpowiada za odświeżanie…
Z tego względu że conky obsługuje IMAP, za to nie obsługuje SSL to o wiele lepszym rozwiązaniem do sprawdzania poczty jest perl. Szczegóły tutaj.
