Potrzebuje pomocy. Program ładuję sie ale nie startuje. Nie mogę odnaleźć przyczyny.
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by javax.media.j3d.JoglPipeline (file:/usr/lib/sweethome3d/java3d-1.6/j3dcore.jar) to method sun.awt.AppContext.getAppContext()
WARNING: Please consider reporting this to the maintainers of javax.media.j3d.JoglPipeline
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
Inconsistency detected by ld.so: dl-lookup.c: 111: check_match: Assertion `version->filename == NULL || ! _dl_name_match_p (version->filename, map)’ failed!
[calvinl@calvin-pc ~]$ sudo snap install sweethome3d-homedesign
[sudo] hasło użytkownika calvinl:
Setup snap "snapd" (5643) security profiles \sweethome3d
-help
--help
2019-12-08T17:49:45+01:00 INFO Waiting for restart...
sweethome3d-homedesign 6.2 from Jean-Baptiste Lallement (jibel) installed
[calvinl@calvin-pc ~]$ sweethome3d
Inconsistency detected by ld.so: dl-lookup.c: 111: check_match: Assertion `version->filename == NULL || ! _dl_name_match_p (version->filename, map)' failed!
[calvinl@calvin-pc ~]$ -help
bash: -help: nie znaleziono polecenia
[calvinl@calvin-pc ~]$ --help
bash: --help: nie znaleziono polecenia
Do wyszukiwania, instalacji i aktualizacji snap’ów, flatpak’ów czy appimage’ów można użyć bauh (community):
$ pamac info bauh
Nazwa : bauh
Opis : Graphical interface to manage Flatpaks, Snaps, AppImages and AUR packages
URL : https://github.com/vinifmor/bauh
