Problem dotyczy gry wymienionej w tytule. Otóż po jakimś czasie od włączenia pokazuje się taki oto komunikat:
po czym gra się wyłącza.
Ustawienie najniższej jakości tekstur i efektów cząsteczkowych nie pomaga.
Oto log gry:
[0.020] Log: Log file open, 04/07/21 12:34:43
[0.020] Init: BioWare Final Build Version: 1.2.20608.0
[0.020] Init: Command line:
[0.020] Init: Base directory: C:\Program Files (x86)\Origin Games\Mass Effect\Binaries\
[0.335] Init: CPU Page size=4096, Processors=4
[0.335] Init: High frequency timer resolution =10.000000 MHz
[0.335] Init: Memory total: Phys=4194303K Pagef=4193791K Virt=4194175K
[39.420] Log: Shader compiling for material Nodebuddy_GOOD took 15.94s
[62.079] Log: Failed to load 'Material None.': Failed to find object 'Material None.'
[62.080] Log: Failed to load 'Material None.': Failed to find object 'Material None.'
[62.084] Log: Failed to load 'Material None.': Failed to find object 'Material None.'
[74.558] Init: Audio Driver: Wbudowany dzwik Analogowe stereo (winemm.vxd)
[79.167] Init: Audio Device: OpenAL Soft
[80.930] Init: 64 Free Sources, 2 Reserved
[100.466] Log: >>>>>>>>>>>>>> Initial startup: 100.47s <<<<<<<<<<<<<<<
[101.275] Log: Bio2DA.cpp::CheckedGetIntEntry(): Failed to read row(1902, isNum=0), column(4) in Bio2DA(Talent_TalentEffectLevels)
[101.275] Log: Bio2DA.cpp::CheckedGetFloatEntry(): Failed to read row(1918, isNum=0), column(4) in Bio2DA(Talent_TalentEffectLevels)
[144.854] Log: Failed to load 'BIOG_2DA_Vegas_Music_X': Can't find file 'BIOG_2DA_Vegas_Music_X'
[164.579] Log: Bio2DA.cpp::CheckedGetIntEntry(): Failed to read row(1902, isNum=0), column(4) in Bio2DA(Talent_TalentEffectLevels)
[164.580] Log: Bio2DA.cpp::CheckedGetFloatEntry(): Failed to read row(1918, isNum=0), column(4) in Bio2DA(Talent_TalentEffectLevels)
[169.122] Log: Closing by request
[170.641] Uninitialized: Log file closed, 04/07/21 12:37:34
Grę uruchamiam poprzez klienta Origin przy pomocy Lutris.
Parametry mojego komputera i systemu:
- Procesor Intel Core i3-5020U 2.20GHz czterordzeniowy
- RAM 12 GB
- Grafika Intel HD Graphics 5500
- Jądro 5.9.16-1
- Środowisko graficzne GNOME 40.beta.0
Ma ktoś jakiś pomysł, co z tym fantem zrobić?
