Podpowiesz co powinno być dokładnie wprowadzone? Mysle, ze nie takiego wyniku oczekiwałeś
journalctl -e --directory=/mnt/var/log/journal
journalctl -e --directory=/mnt/var/log/journal ✔
Aug 31 08:47:48 KnifcioXPS15 kernel: vboxdrv: Found 8 processor cores/threads
Aug 31 08:47:48 KnifcioXPS15 systemd[1]: Finished Create List of Static Device Nodes.
Aug 31 08:47:48 KnifcioXPS15 systemd[1]: modprobe@configfs.service: Deactivated successfully.
Aug 31 08:47:48 KnifcioXPS15 kernel: vboxdrv: TSC mode is Invariant, tentative frequency 2808010521 Hz
Aug 31 08:47:48 KnifcioXPS15 kernel: vboxdrv: Successfully loaded version 7.0.10 r158379 (interface 0x00330004)
Aug 31 08:47:48 KnifcioXPS15 kernel: VBoxNetAdp: Successfully started.
Aug 31 08:47:48 KnifcioXPS15 kernel: VBoxNetFlt: Successfully started.
Aug 31 08:47:48 KnifcioXPS15 systemd[1]: Finished Load Kernel Module configfs.
Aug 31 08:47:48 KnifcioXPS15 systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
Aug 31 08:47:48 KnifcioXPS15 systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
Aug 31 08:47:48 KnifcioXPS15 systemd[1]: Finished Load Kernel Module dm_mod.
Aug 31 08:47:48 KnifcioXPS15 systemd[1]: modprobe@drm.service: Deactivated successfully.
Aug 31 08:47:48 KnifcioXPS15 systemd[1]: Finished Load Kernel Module drm.
Aug 31 08:47:48 KnifcioXPS15 systemd[1]: modprobe@fuse.service: Deactivated successfully.
Aug 31 08:47:48 KnifcioXPS15 systemd[1]: Finished Load Kernel Module fuse.
Aug 31 08:47:48 KnifcioXPS15 systemd[1]: modprobe@loop.service: Deactivated successfully.
Aug 31 08:47:48 KnifcioXPS15 systemd[1]: Finished Load Kernel Module loop.
Aug 31 08:47:48 KnifcioXPS15 systemd[1]: Finished Remount Root and Kernel File Systems.
Aug 31 08:47:48 KnifcioXPS15 systemd[1]: Finished Coldplug All udev Devices.
Aug 31 08:47:48 KnifcioXPS15 systemd[1]: Mounting FUSE Control File System...
Aug 31 08:47:48 KnifcioXPS15 systemd[1]: Mounting Kernel Configuration File System...
Aug 31 08:47:48 KnifcioXPS15 systemd[1]: First Boot Wizard was skipped because of an unmet condition check (ConditionFirstBoot=yes).
Aug 31 08:47:48 KnifcioXPS15 systemd[1]: Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
Aug 31 08:47:48 KnifcioXPS15 systemd[1]: Starting Load/Save OS Random Seed...
Aug 31 08:47:48 KnifcioXPS15 systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
Aug 31 08:47:48 KnifcioXPS15 systemd[1]: Create System Users was skipped because no trigger condition checks were met.
Aug 31 08:47:48 KnifcioXPS15 systemd[1]: Starting Create Static Device Nodes in /dev...
Aug 31 08:47:48 KnifcioXPS15 systemd[1]: Starting Setup Virtual Console...
Aug 31 08:47:48 KnifcioXPS15 systemd[1]: Mounted FUSE Control File System.
Aug 31 08:47:48 KnifcioXPS15 systemd[1]: Mounted Kernel Configuration File System.
Aug 31 08:47:48 KnifcioXPS15 systemd[1]: Finished Load/Save OS Random Seed.
Aug 31 08:47:48 KnifcioXPS15 systemd[1]: Finished Setup Virtual Console.
Aug 31 08:47:48 KnifcioXPS15 systemd[1]: First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes).
Aug 31 08:47:48 KnifcioXPS15 systemd[1]: Finished Create Static Device Nodes in /dev.
Aug 31 08:47:48 KnifcioXPS15 systemd[1]: Reached target Preparation for Local File Systems.
Aug 31 08:47:48 KnifcioXPS15 systemd[1]: Virtual Machine and Container Storage (Compatibility) was skipped because of an unmet condition check (ConditionPathExists=/var/lib/machines.raw).
Aug 31 08:47:48 KnifcioXPS15 systemd[1]: var-lib-snapd-snap.mount: Directory /var/lib/snapd/snap to mount over is not empty, mounting anyway.
Aug 31 08:47:48 KnifcioXPS15 systemd[1]: Mounting Ensure that the snap directory shares mount events....
Aug 31 08:47:48 KnifcioXPS15 systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped because of an unmet condition check (ConditionKernelVersion=<5.6).
Aug 31 08:47:48 KnifcioXPS15 systemd[1]: Starting Journal Service...
Aug 31 08:47:48 KnifcioXPS15 systemd[1]: Starting Rule-based Manager for Device Events and Files...
Aug 31 08:47:48 KnifcioXPS15 systemd[1]: Mounted Ensure that the snap directory shares mount events..
Aug 31 08:47:48 KnifcioXPS15 systemd-journald[315]: Collecting audit messages is disabled.
Aug 31 08:47:48 KnifcioXPS15 systemd-journald[315]: Journal started
Aug 31 08:47:48 KnifcioXPS15 systemd-journald[315]: Runtime Journal (/run/log/journal/4986ec0329894e24a565e096047247ee) is 8.0M, max 786.0M, 778.0M free.
Aug 31 08:47:48 KnifcioXPS15 systemd-modules-load[299]: Inserted module 'crypto_user'
Aug 31 08:47:48 KnifcioXPS15 systemd-modules-load[299]: Inserted module 'vboxdrv'
Aug 31 08:47:48 KnifcioXPS15 systemd-modules-load[299]: Inserted module 'vboxnetadp'
Aug 31 08:47:48 KnifcioXPS15 systemd-modules-load[299]: Inserted module 'vboxnetflt'
Aug 31 08:47:48 KnifcioXPS15 systemd-vconsole-setup[310]: Failed to import credentials, ignoring: Nie ma takiego pliku ani katalogu
Aug 31 08:47:48 KnifcioXPS15 systemd[1]: Starting Flush Journal to Persistent Storage...
Aug 31 08:47:48 KnifcioXPS15 systemd[1]: Started Rule-based Manager for Device Events and Files.
Aug 31 08:47:48 KnifcioXPS15 systemd[1]: Started Journal Service.
Aug 31 08:47:48 KnifcioXPS15 systemd[1]: Starting Show Plymouth Boot Screen...
Aug 31 08:47:48 KnifcioXPS15 systemd-journald[315]: Time spent on flushing to /var/log/journal/4986ec0329894e24a565e096047247ee is 12.414ms for 972 entries.
**findmnt -l **
findmnt -l
TARGET SOURCE FSTYPE OPTIONS
/proc proc proc rw,nosuid,nodev,noexec,relatime
/sys sys sysfs rw,nosuid,nodev,noexec,relatime
/dev dev devtmpfs rw,nosuid,relatime,size=8020664k,nr_inodes=2005166,mode=755,inode64
/run run tmpfs rw,nosuid,nodev,relatime,mode=755,inode64
/sys/firmware/efi/efivars efivarfs efivarfs rw,nosuid,nodev,noexec,relatime
/run/miso/bootmnt /dev/sda1 iso9660 ro,relatime,nojoliet,check=s,map=n,blocksize=2048,iocharset=utf8
/run/miso/cowspace cowspace tmpfs rw,relatime,size=262144k,mode=755,inode64
/run/miso/overlay_root overlay_root tmpfs rw,relatime,size=12074792k,mode=755,inode64
/run/miso/sfs/livefs /dev/loop0 squashfs ro,relatime,errors=continue
/run/miso/sfs/mhwdfs /dev/loop1 squashfs ro,relatime,errors=continue
/run/miso/sfs/desktopfs /dev/loop2 squashfs ro,relatime,errors=continue
/run/miso/sfs/rootfs /dev/loop3 squashfs ro,relatime,errors=continue
/ overlay overlay rw,relatime,lowerdir=/run/miso/sfs/livefs:/run/miso/sfs/mhwdfs:/run/miso/sfs/desktopfs:/run/miso/sfs/rootfs,upperdir=/run/miso/overlay_root/upper,workdir=/run/miso/overlay_root/wo
/sys/kernel/security securityfs securityfs rw,nosuid,nodev,noexec,relatime
/dev/shm tmpfs tmpfs rw,nosuid,nodev,inode64
/dev/pts devpts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
/sys/fs/cgroup cgroup2 cgroup2 rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
/sys/fs/pstore pstore pstore rw,nosuid,nodev,noexec,relatime
/sys/fs/bpf bpf bpf rw,nosuid,nodev,noexec,relatime,mode=700
/proc/sys/fs/binfmt_misc systemd-1 autofs rw,relatime,fd=33,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=15186
/dev/mqueue mqueue mqueue rw,nosuid,nodev,noexec,relatime
/sys/kernel/debug debugfs debugfs rw,nosuid,nodev,noexec,relatime
/sys/kernel/tracing tracefs tracefs rw,nosuid,nodev,noexec,relatime
/dev/hugepages hugetlbfs hugetlbfs rw,relatime,pagesize=2M
/tmp tmpfs tmpfs rw,nosuid,nodev,nr_inodes=1048576,inode64
/sys/fs/fuse/connections fusectl fusectl rw,nosuid,nodev,noexec,relatime
/sys/kernel/config configfs configfs rw,nosuid,nodev,noexec,relatime
/run/credentials/systemd-sysctl.service
ramfs ramfs ro,nosuid,nodev,noexec,relatime,mode=700
/run/credentials/systemd-tmpfiles-setup-dev.service
/etc/pacman.d/gnupg tmpfs tmpfs rw,relatime,mode=755,inode64
/run/credentials/systemd-tmpfiles-setup.service
/run/user/1000 tmpfs tmpfs rw,nosuid,nodev,relatime,size=1609972k,nr_inodes=402493,mode=700,uid=1000,gid=1000,inode64
/run/user/1000/doc portal fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
/run/media/manjaro/747b824b-b018-435d-9ad3-bb096384409f
/dev/nvme0n1p2 ext4 rw,nosuid,nodev,relatime,errors=remount-ro
/mnt /dev/nvme0n1p2 ext4 rw,relatime,errors=remount-ro
/mnt/boot/efi /dev/nvme0n1p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
/mnt/proc proc proc rw,nosuid,nodev,noexec,relatime
/mnt/sys sys sysfs ro,nosuid,nodev,noexec,relatime
/mnt/sys/firmware/efi/efivars efivarfs efivarfs rw,nosuid,nodev,noexec,relatime
/mnt/dev udev devtmpfs rw,nosuid,relatime,size=8020664k,nr_inodes=2005166,mode=755,inode64
/mnt/dev/pts devpts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
/mnt/dev/shm shm tmpfs rw,nosuid,nodev,relatime,inode64
/mnt/run run tmpfs rw,nosuid,nodev,relatime,mode=755,inode64
/mnt/tmp tmp tmpfs rw,nosuid,nodev,inode64
/mnt/etc/resolv.conf overlay[/etc/resolv.conf//deleted]
Wczeniej podalem journalctl -e --directory=/dev/nvme0n1p2/var/log/journal, ale to nic nie dalo
Jednak, aby nie pytac o kazda drobnostke, znalazlem w sieci aby wykonac (z rozwaga)
- manjaro-chroot -a
- journalctl -b-1 --no-pager
Niestety godziny zaczynaj sie po 19, a problem wystapil w okolicy godziny 12:30 - 14:00 od tamtej pory do 20 walczylem z problemem.
d9vQpqwuHq
Dodatkowe polecenia, ktorych wynik zapisalem do pliku. Czy podeslas cos?
1. journalctl -b-1 -p4 --no-pager
2. pacmanlog
3. lsblk -f
4. mhwd-kernel -li && mhwd -l -li
5. inxi -v7azy
