Witam serdecznie.
Przerabiał ktoś instalacje xampp jak to jest z uprawnieniami?
Instalacja prosta idzie to z pliku .run
Do uruchomienia apache potrzebowałem doinstalować pakiet “libxcrypt-compat”
Moje pytanie jak potraktować folder /opt/lampp/htdocs ?
Sam sobie odpowiem, dość ładnie opisane jest to tutaj:
# Download Xampp from Official Website
1. Download "Xampp for Linux" from ApacheFriends website: https://www.apachefriends.org/download.html
2. The downloaded file will be saved on the default save folder of your browser. In my case, it saved on "Desktop" under my "Home" folder. The filename was **xampp-linux-x64-7.4.1-1-installer.run**.
**N.B.** Check this Linux FAQ for installation guidelines: https://www.apachefriends.org/faq_linux.html
# Install Xampp on Manjaro
1. Open Terminal. Navigate to "Desktop" folder.
2. Issue the following two commands to start the automated installer.
chmod 755 xampp-linux-*-installer.run
sudo ./xampp-linux-*-installer.run
3. After a brief while, Xampp installer will pop up on the screen. Follow the instructions of the installer.
That's all. XAMPP is now installed below the /opt/lampp directory.
This file has been truncated. show original
Temat do zamknięcia. Pozdrawiam serdecznie.
