siemano
Cos sie popsulo mam jednoczesnie dzwiek w sluchawkach i w glosniku laptopa.
Nie udaje mi sie ustawic tylko w sluchawkach. Albo w sluchawkach i glosnik lub wcale ;/
Czy mozna wywalic to pipwire i pulse i miec tylko czysta alse?
Kolejna sprawa to zeby w ogole miec dzwiek to po starcie odpalic musze mixer i wybrac karte bo inaczej tez nic z tego.
Problem po ktorejs aktualizacji powstal lub instalacji programiku jakiegos ;/
$ inxi --admin --verbosity=7 --filter --no-host --width
System:
Kernel: 5.19.1-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
parameters: initrd=\intel-ucode.img initrd=\initramfs-5.19-x86_64.img
root=UUID=f7100c39-8f36-4856-8ad5-4180bd83bbfa rw
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Machine:
Type: Laptop System: Hewlett-Packard product: HP EliteBook 8470p
v: A1029D1102 serial: <superuser required> Chassis: type: 10
Mobo: Hewlett-Packard model: 179B v: KBC Version 42.36
serial: <superuser required> UEFI: Hewlett-Packard v: 68ICF Ver. F.43
date: 07/16/2013
Battery:
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M185
serial: <filter> charge: 55% (should be ignored) rechargeable: yes
status: discharging
Memory:
RAM: total: 9.59 GiB used: 4.53 GiB (47.2%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
CPU:
Info: model: Intel Core i5-3340M bits: 64 type: MT MCP arch: Ivy Bridge
gen: core 3 level: v3 built: 2012-15 process: Intel 22nm family: 6
model-id: 0x3A (58) stepping: 9 microcode: 0x21
Topology: cpus: 1x cores: 2 tpc: 2 threads: 4 smt: enabled cache:
L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1325 high: 1700 min/max: 1200/3400 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1200 2: 1700 3: 1200
4: 1200 bogomips: 21556
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
ept erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs
ida lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx
pae pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
rdrand rdtscp rep_good sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid
x2apic xsave xsaveopt xtopology xtpr
Vulnerabilities:
Type: itlb_multihit status: KVM: VMX disabled
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT
vulnerable
Type: mds mitigation: Clear CPU buffers; SMT vulnerable
Type: meltdown mitigation: PTI
Type: mmio_stale_data status: Not affected
Type: retbleed status: Not affected
Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via
prctl
Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer
sanitization
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, IBRS_FW,
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Type: srbds status: Vulnerable: No microcode
Graphics:
Device-1: Intel 3rd Gen Core processor Graphics vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen-7 process: Intel 22nm built: 2012-13 ports:
active: LVDS-1 empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3,
VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0.0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: LVDS-1 model: AU Optronics 0x253c built: 2012 res: 1366x768
hz: 60 dpi: 112 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1366x768
OpenGL: renderer: Mesa Intel HD Graphics 4000 (IVB GT2) v: 4.2 Mesa 22.1.6
direct render: Yes
Audio:
Device-1: Intel 7 Series/C216 Family High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1e20 class-ID: 0403
Sound Server-1: ALSA v: k5.19.1-3-MANJARO running: yes
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.56 running: yes
Network:
Device-1: Intel 82579LM Gigabit Network vendor: Hewlett-Packard
driver: e1000e v: kernel port: 2060 bus-ID: 00:19.0 chip-ID: 8086:1502
class-ID: 0200
IF: enp0s25 state: up speed: 100 Mbps duplex: full mac: <filter>
IP v4: <filter> type: dynamic noprefixroute scope: global
broadcast: <filter>
IP v6: <filter> type: noprefixroute scope: link
Device-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0
chip-ID: 8086:0082 class-ID: 0280
IF: wlo1 state: down mac: <filter>
WAN IP: <filter>
Bluetooth:
Device-1: Broadcom HP Portable SoftSailing type: USB driver: btusb v: 0.8
bus-ID: 2-1.6:3 chip-ID: 0a5c:21e1 class-ID: fe01 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
rfk-block: hardware: no software: yes address: see --recommends
Logical:
Message: No logical block device data found.
RAID:
Message: No RAID data found.
Drives:
Local Storage: total: 223.57 GiB used: 160.76 GiB (71.9%)
SMART Message: Required tool smartctl not installed. Check --recommends
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: B1D2 scheme: GPT
Optical-1: /dev/sr0 vendor: hp model: DVD A DS8A9SH rev: EH61
dev-links: cdrom
Features: speed: 24 multisession: yes audio: yes dvd: yes
rw: cd-r,cd-rw,dvd-r,dvd-ram state: running
Partition:
ID-1: / raw-size: 195.36 GiB size: 191.24 GiB (97.89%) used: 160.66 GiB
(84.0%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: f7100c39-8f36-4856-8ad5-4180bd83bbfa
ID-2: /boot raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 108.5 MiB
(36.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A uuid: 024B-975D
Swap:
Alert: No swap data was found.
Unmounted:
Message: No unmounted partitions found.
USB:
Hub-1: 1-0:1 info: Full speed or root hub ports: 3 rev: 2.0 speed: 480 Mb/s
chip-ID: 1d6b:0002 class-ID: 0900
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Hub-3: 2-0:1 info: Full speed or root hub ports: 3 rev: 2.0
speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Device-1: 2-1.6:3 info: Broadcom HP Portable SoftSailing type: Bluetooth
driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s chip-ID: 0a5c:21e1
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-4:2 info: Logitech Unifying Receiver type: Mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c52f class-ID: 0300
Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 1d6b:0003 class-ID: 0900
Sensors:
System Temperatures: cpu: 54.0 C mobo: N/A
Fan Speeds (RPM): N/A
Info:
Processes: 225 Uptime: 4h 24m wakeups: 19 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.1 clang: 14.0.6
Packages: pm: pacman pkgs: 1618 libs: 454 tools: pacaur,pamac,trizen,yay
pm: flatpak pkgs: 0 Shell: Bash v: 5.1.16 running-in: xfce4-terminal
inxi: 3.3.21
````Tekst sformatowany`
> Cytat
