Bootsplash i systemd wolny
to jest plymouth?? jak to osiagnac? mam laptopa z kartami intela i nvidii …
wogole systemd zwolnil strasznie i bledami pluje
sysinit.target: Job cryptsetup.target/start deleted to break ordering cycle starting with sysinit.target/start
systemd-analyze blame
         1.835s upower.service
         1.366s dev-sda1.device
         1.247s systemd-modules-load.service
         1.208s systemd-logind.service
          801ms systemd-udevd.service
          632ms systemd-journald.service
          602ms swapfile.swap
          415ms udisks2.service
          321ms tlp.service
          278ms systemd-journal-flush.service
          267ms systemd-update-utmp.service
          217ms systemd-tmpfiles-clean.service
          216ms systemd-vconsole-setup.service
          215ms NetworkManager.service
          190ms avahi-daemon.service
          179ms polkit.service
          170ms lm_sensors.service
          155ms systemd-journal-catalog-update.service
          153ms bluetooth.service
          148ms systemd-udev-trigger.service
          120ms home.mount
          101ms systemd-tmpfiles-setup.service
           85ms user@1000.service
           77ms systemd-sysusers.service
           61ms rtkit-daemon.service
           48ms systemd-remount-fs.service
           46ms systemd-binfmt.service
           45ms systemd-update-done.service
           45ms wpa_supplicant.service
           42ms plymouth-start.service
           36ms systemd-random-seed.service
           36ms systemd-sysctl.service
           34ms plymouth-read-write.service
           24ms plymouth-quit-wait.service
           21ms systemd-tmpfiles-setup-dev.service
           20ms dev-hugepages.mount
           19ms kmod-static-nodes.service
           18ms sys-kernel-config.mount
           15ms grub-boot-indeterminate.service
           15ms systemd-backlight@backlight:intel_backlight.service
           14ms dev-mqueue.mount
           13ms systemd-user-sessions.service
           12ms plymouth-quit.service
           10ms user-runtime-dir@1000.service
            6ms proc-sys-fs-binfmt_misc.mount
            5ms tmp.mount
nieogarniam tego systemd … wogole jak mam odpalone 2 przegladarki to jak zminimalizuje 1 to 2 dziala ze 3 razy szybciej … czego to wina xorga?
uzywam
5.0.5-1-ck-ivybridge #1 SMP PREEMPT Thu Mar 28 17:33:53 EDT 2019 x86_64 GNU/Linux
Zauważ na #bladebook
czyli https://manjaro.org/hardware-bladebook/
jak dla mnie to jest zbędne zabiera zasoby przy starcie bez potrzeby :wink:
i jeszcze to
wywal plymouth i zobacz co się stanie…
tak samo bootsplash zbyteczny bajer…
który na pewno nie poprawia pracy systemu :wink:
no ale mamy wolność każdy robi ze swoim sprzętem co chce…
boosplash jest niezbedny tylko niechce tydzien na archwiki spedzic … jest w manjaro cos w rodzaju security? przeciez to niepowazne ze pakiety z dziurami czekaja w stable na upgrade miesiacami
bootsplash - miałem na myśli graficzny nic innego ( ja nie mam i jest wszystko poprawnie :wink: )
@ppp666
A skąd Ty masz plymouth w systemie? przecież on został usunięty z Manjaro, bodajże od wersji 17.1.
z extra chyba ci sie pomylilo bo zostal dodany niedawno … bo jakis czas temu z aur
plymouth
Chyba że od wersji 18 znowu go przywrócili, na szczęście nie używam Manjaro, więc nie mam tego problemu.
ale nie znaczy że trzeba z niego korzystać :wink:
jest pełno pakietów w repo a z wszystkich się nie korzysta :smiley:
ale ja chce!!:rofl: a jak naprawic ten blad crypsetup?? i jeszcze 1 najlepszym sposobem na zmiane shedulera io jest dodanie do cmd kernela (
Panowie sobie o Plymouth gaworzą, a ja gorę !
To nie Plymouth tylko Bootsplash. Ten pierwszy, to zewnętrze rozwiązanie działające w przestrzeni użytkownika (generalnie spełnia swoje zadanie - ładnie wygląda - ale czasem, są z nim problemy i generuje narzut czasowy); ten drugi jest elementem jądra (dostępnym już od jakiego czasu, choć niemrawo implementowanym). Oprócz link’u podrzuconego przez @UltherEgo, zajrzyjcie również do poniższych:
Jeżeli ktoś chce mieć ładny boot systemu, to radzę porzucić Plymouth i zainwestować odrobinę czasu w Bootsplash. Wszystko wskazuje na to, że pierwsze rozwiązanie odchodzi do historii (spełniło swoje zadanie), a najbliższa przyszłość należy do Bootsplash’a lub czegoś podobnego.
@ppp666 -> jeden wątek, jeden temat.
Dzięki azja , pobawiłem się i teraz mój system startuje prawie jak win10 :slightly_smiling_face:
Wystarczy zrobić to co w jednym z linków :
How to install bootsplash on Manjaro v18.0
  • install the wanted theme and bootsplash-systemd
  • replace %THEME% with the package name after bootsplash-theme in the following two steps (example: for bootsplash-theme-manjaro %THEME% becomes manjaro )
    • add bootsplash-%THEME% to HOOKS in /etc/mkinitcpio.conf
    • add bootsplash.bootfile=bootsplash-themes/%THEME%/bootsplash to GRUB_CMDLINE_LINUX_DEFAULT in /etc/default/grub and make sure you removed QUIET .
  • You may want to consider early kms and fastboot for intel hardware
  • update your initramfs via mkinitcpio -P
  • update your grub.cfg via update-grub
  • reboot
i działa :grinning:
no to gratulacje :slight_smile:
tylko tak z ciekawości się zastanawiam co to miało na celu coby upodabniać do win 10?
kręcące się kółko z kropek
@warsztat-dom
  • /etc/mkinitcpio.conf
    W którym miejscu (w jakiej kolejności) dodałeś pozycję w HOOKS, bo ma to znaczenie. Na końcu listy?
  • /etc/default/grub
    Podobnie j.w., na końcu wiersza? Choć tutaj kolejność chyba nie ma znaczenia.
  • windows’owe kółko z kropek spodobało mi się, jak tylko je zobaczyłem, ale z czasem zaczęło mi się kojarzyć z długim oczekiwaniem i brakiem informacji w jakim punkcie operacji jestem oraz jak długo, to jeszcze potrwa (15 minut, czy 5 godzin).
oba na końcu wiersza, kółko z kropek już wywaliłem bo napisy chyba fajniejsze ale chodziło chyba tyle samo czasu co napisy chyba że jest coś ładniejszego ale nie chciało mi się tego po kolei próbować
(edit po 1h) no i zaszalałem znowu, w starym hp 6710b ustawiłem splash xfce oraz dodałem fastboot i botowanie szybkie jak nigdy z kółkiem pod logo xfce :grinning:
forum.manjaro.pl - polskie wsparcie Manjaro. Hostowane przez:
