Napisałem prosty skrypt do regulacji głośności. Po uruchomieniu w terminalu działa jak należy.
#!/bin/bash
amixer scontrols
amixer sset 'Master' 30%
sleep 10
amixer -q -D pulse sset Master 10%+
sleep 10
sleep 10
sleep 10
sleep 10
sleep 10
Przy próbie uruchomienia z crontaba niestety nie działa.
Simple mixer control 'PCM',0
Simple mixer control 'Line',0
Simple mixer control 'Line Boost',0
Simple mixer control 'Mic',0
Simple mixer control 'Mic Boost',0
Simple mixer control 'IEC958',0
Simple mixer control 'IEC958',1
Simple mixer control 'IEC958',2
Simple mixer control 'Beep',0
Simple mixer control 'Capture',0
Simple mixer control 'Auto-Mute Mode',0
Simple mixer control 'Digital',0
Simple mixer control 'Internal Mic Boost',0
Simple mixer control 'Loopback Mixing',0
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Limits: Playback 0 - 127
Mono: Playback 38 [30%] [-66.75dB] [on]
ALSA lib pulse.c:242:(pulse_connect) PulseAudio: Unable to connect: Connection refused
amixer: Mixer attach pulse error: Connection refused
Może ktoś z forumowiczów będzie miał jakiś pomysł jak to ogarnąć.
