Hej wszystkim.
Mam problem z instalowaniem tuxguitar, widzę że w terminalu jest link pomocny (MojoExecutionException - Apache Maven - Apache Software Foundation), ale niestety nie rozumiem jak go użyć i rozwiązać mój problem. Ktoś jest w stanie pomóc mi w tym? Dzięki!
compile-native:
[exec] gcc -I/home/robertw/.cache/yay/tuxguitar/src/tuxguitar-1.5.4-src/build-scripts/native-modules/tuxguitar-alsa-linux-x86_64/../common-include -m64 -fPIC -c -o org_herac_tuxguitar_player_impl_midiport_alsa_MidiSystem.o org_herac_tuxguitar_player_impl_midiportmake: gcc: Nie ma takiego pliku ani katalogu
[exec] make: *** [GNUmakefile:13: org_herac_tuxguitar_player_impl_midiport_alsa_MidiSystem.o] Błąd 127
[exec] _alsa_MidiSystem.c
[INFO] ------------------------------------------------------------------------
[INFO] Reactor Summary for tuxguitar-alsa-linux-x86_64 1.5.4:
[INFO]
[INFO] tuxguitar-alsa ..................................... SUCCESS [ 1.425 s]
[INFO] tuxguitar-alsa-linux-x86_64 ........................ FAILURE [ 1.248 s]
[INFO] BUILD FAILURE
[INFO] Total time: 2.781 s
[INFO] Finished at: 2020-11-06T12:18:00+01:00
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-antrun-plugin:1.7:run (compile-native) on project tuxguitar-alsa-linux-x86_64: An Ant BuildException has occured: exec returned: 2
[ERROR] around Ant part ...<exec failonerror="true" dir="../../..//TuxGuitar-alsa/jni/" executable="make">... @ 4:82 in /home/robertw/.cache/yay/tuxguitar/src/tuxguitar-1.5.4-src/build-scripts/native-modules/tuxguitar-alsa-linux-x86_64/target/antrun/build-compile-native.xml
[ERROR] -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] After correcting the problems, you can resume the build with the command
[ERROR] mvn <args> -rf :tuxguitar-alsa-linux-x86_64
==> BŁĄD: Wystąpił błąd w build().
Przerywam...
